Time Before: 0.00158 seconds
Time After: 0.00209 seconds
Time Before: 0.00216 seconds
Time After: 0.00267 seconds
Time Before: 0.00298 seconds
Time After: 0.00311 seconds
Time Before: 0.00399 seconds
Time After: 0.00695 seconds
Time Taken: 0.00296 seconds
Time Before: 0.00318 seconds
Time After: 0.01090 seconds
Time Taken: 0.00772 seconds
Time Before: 0.01301 seconds
Time After: 0.01343 seconds
Time Before: 0.01648 seconds
Time After: 0.01796 seconds
Time Before: 0.01240 seconds
Time After: 0.01817 seconds
Time Taken: 0.00577 seconds
Time Before: 0.02356 seconds
Time After: 0.02369 seconds
Time Before: 0.02553 seconds
Time After: 0.02674 seconds
Time Before: 0.02968 seconds
Time After: 0.02983 seconds
Time Before: 0.03185 seconds
Time After: 0.03329 seconds
UPDATE session SET lastactivity = 1788973790, location = '/forums/private.php?do=newpm&explain=1&u=99964' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04562 seconds
Time After: 0.04591 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
