Time Before: 0.00754 seconds
Time After: 0.00966 seconds
Time Taken: 0.00212 seconds
Memory Before: 2,054.688 KB
Memory After: 2,079.805 KB
Time Before: 0.00976 seconds
Time After: 0.01021 seconds
Memory Before: 2,079.742 KB
Memory After: 2,080.750 KB
Time Before: 0.01054 seconds
Time After: 0.01068 seconds
Memory Before: 2,081.359 KB
Memory After: 2,081.883 KB
WHERE title IN ('smiliecache','bbcodecache','banemail','ranks','noavatarperms','navdata','options','bitfields','attachmentcache','forumcache','usergroupcache','stylecache','languagecache','products','pluginlist','cron','profilefield','loadcache','noticecache','activitystream','routes')
1SIMPLEdatastorerangePRIMARYPRIMARY52 21Using where
Time Before: 0.01163 seconds
Time After: 0.01442 seconds
Time Taken: 0.00278 seconds
Memory Before: 2,084.508 KB
Memory After: 2,085.445 KB
Memory Used: 0.938 KB
Time Before: 0.01077 seconds
Time After: 0.02042 seconds
Time Taken: 0.00965 seconds
Memory Before: 2,081.102 KB
Memory After: 3,170.094 KB
Memory Used: 1,088.992 KB
Time Before: 0.02509 seconds
Time After: 0.02552 seconds
Memory Before: 3,662.922 KB
Memory After: 3,663.539 KB
			phrasegroup_timezone AS phrasegroup_timezone,
			phrasegroup_cprofilefield AS phrasegroup_cprofilefield,
			phrasegroup_cppermission AS phrasegroup_cppermission,
Time Before: 0.02814 seconds
Time After: 0.02951 seconds
Time Taken: 0.00137 seconds
Memory Before: 3,674.898 KB
Memory After: 3,674.773 KB
Memory Used: -0.125 KB
Time Before: 0.02372 seconds
Time After: 0.02975 seconds
Time Taken: 0.00603 seconds
Memory Before: 3,655.070 KB
Memory After: 3,805.195 KB
Memory Used: 150.125 KB
Time Before: 0.04439 seconds
Time After: 0.04454 seconds
Memory Before: 4,409.734 KB
Memory After: 4,410.250 KB
Time Before: 0.05192 seconds
Time After: 0.05316 seconds
Memory Before: 4,497.508 KB
Memory After: 4,498.102 KB
End call of global.php: 0.055131196975708
Time Before: 0.05970 seconds
Time After: 0.05986 seconds
Memory Before: 5,135.688 KB
Memory After: 5,136.133 KB
Memory Used: 0.445 KB
WHERE templateid IN (62234,62232,55071,57273,57295,62316,0,0,6082,38961,42855,57213,38966,57292,5992,38968,38969,57230,62031,62305,45486,61981,53288,61979,61980,62335,0,0,62315,62276,62001,62002,62004,62005,62228,62347,62329,62279,62280,61828,61827,61831,61422,61391,61420,61659)
1SIMPLEtemplaterangePRIMARYPRIMARY4 43Using where
Time Before: 0.06242 seconds
Time After: 0.06355 seconds
Time Taken: 0.00113 seconds
Memory Before: 5,406.438 KB
Memory After: 5,407.703 KB
Memory Used: 1.266 KB
SET location = '/forums/profile.php?do=switchusercss&explain=1&u=101100'
WHERE sessionhash = '66cebdc136219950b4ff3c4279e7e516'
Time Before: 0.08070 seconds
Time After: 0.08103 seconds
Memory Before: 5,857.320 KB
Memory After: 5,857.555 KB
Memory Used: 0.234 KB
Page generated in 0.079469203948975 seconds with 9 queries, spending 0.0081765651702881 doing MySQL queries and 0.071292638778687 doing PHP things.
