Time Before: 0.03257 seconds
Time After: 0.03859 seconds
Time Taken: 0.00602 seconds
Memory Before: 2,056.789 KB
Memory After: 2,081.906 KB
Time Before: 0.03870 seconds
Time After: 0.03903 seconds
Memory Before: 2,081.844 KB
Memory After: 2,082.852 KB
Time Before: 0.03935 seconds
Time After: 0.03951 seconds
Memory Before: 2,083.461 KB
Memory After: 2,083.984 KB
Time Before: 0.04040 seconds
Time After: 0.04398 seconds
Time Taken: 0.00358 seconds
Memory Before: 2,086.609 KB
Memory After: 2,087.547 KB
Memory Used: 0.938 KB
Time Before: 0.03959 seconds
Time After: 0.04803 seconds
Time Taken: 0.00844 seconds
Memory Before: 2,083.203 KB
Memory After: 3,172.195 KB
Memory Used: 1,088.992 KB
Time Before: 0.05860 seconds
Time After: 0.05903 seconds
Memory Before: 3,665.016 KB
Memory After: 3,665.633 KB
Time Before: 0.06039 seconds
Time After: 0.06246 seconds
Time Taken: 0.00207 seconds
Memory Before: 3,676.977 KB
Memory After: 3,676.852 KB
Memory Used: -0.125 KB
Time Before: 0.05793 seconds
Time After: 0.06271 seconds
Time Taken: 0.00478 seconds
Memory Before: 3,657.164 KB
Memory After: 3,806.945 KB
Memory Used: 149.781 KB
Time Before: 0.11680 seconds
Time After: 0.11697 seconds
Memory Before: 4,411.414 KB
Memory After: 4,411.930 KB
Time Before: 0.56142 seconds
Time After: 0.56299 seconds
Time Taken: 0.00158 seconds
Memory Before: 4,499.086 KB
Memory After: 4,499.680 KB
Time Before: 0.57385 seconds
Time After: 0.57399 seconds
Memory Before: 5,137.227 KB
Memory After: 5,137.672 KB
Memory Used: 0.445 KB
Time Before: 0.57650 seconds
Time After: 0.57839 seconds
Time Taken: 0.00188 seconds
Memory Before: 5,407.891 KB
Memory After: 5,409.156 KB
Memory Used: 1.266 KB
UPDATE session SET location = '/forums/profile.php?do=switchusercss&explain=1&u=103682', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.59817 seconds
Time After: 0.59845 seconds
Memory Before: 5,846.484 KB
Memory After: 5,846.703 KB
