Time Before: 0.00136 seconds
Time After: 0.00189 seconds
Time Taken: 0.00053 seconds
Memory Before: 2,056.352 KB
Memory After: 2,081.469 KB
Time Before: 0.00196 seconds
Time After: 0.00255 seconds
Time Taken: 0.00059 seconds
Memory Before: 2,081.406 KB
Memory After: 2,082.414 KB
Time Before: 0.00280 seconds
Time After: 0.00295 seconds
Memory Before: 2,082.992 KB
Memory After: 2,083.516 KB
WHERE title IN ('smiliecache','bbcodecache','banemail','ranks','noavatarperms','navdata','options','bitfields','attachmentcache','forumcache','usergroupcache','stylecache','languagecache','products','pluginlist','cron','profilefield','loadcache','noticecache','activitystream','routes')
1SIMPLEdatastorerangePRIMARYPRIMARY52 21Using where
Time Before: 0.00372 seconds
Time After: 0.00666 seconds
Time Taken: 0.00294 seconds
Memory Before: 2,086.141 KB
Memory After: 2,087.078 KB
Memory Used: 0.938 KB
Time Before: 0.00300 seconds
Time After: 0.01043 seconds
Time Taken: 0.00743 seconds
Memory Before: 2,082.766 KB
Memory After: 3,171.813 KB
Memory Used: 1,089.047 KB
Time Before: 0.01279 seconds
Time After: 0.01315 seconds
Memory Before: 3,664.609 KB
Memory After: 3,665.227 KB
			phrasegroup_timezone AS phrasegroup_timezone,
			phrasegroup_cprofilefield AS phrasegroup_cprofilefield,
			phrasegroup_cppermission AS phrasegroup_cppermission,
Time Before: 0.01557 seconds
Time After: 0.01866 seconds
Time Taken: 0.00309 seconds
Memory Before: 3,676.570 KB
Memory After: 3,676.445 KB
Memory Used: -0.125 KB
Time Before: 0.01204 seconds
Time After: 0.01884 seconds
Time Taken: 0.00680 seconds
Memory Before: 3,656.789 KB
Memory After: 3,806.570 KB
Memory Used: 149.781 KB
Time Before: 0.02512 seconds
Time After: 0.02525 seconds
Memory Before: 4,411.047 KB
Memory After: 4,411.563 KB
Time Before: 0.02796 seconds
Time After: 0.02919 seconds
Memory Before: 4,498.742 KB
Memory After: 4,499.336 KB
End call of global.php: 0.031819820404053
Time Before: 0.03332 seconds
Time After: 0.03345 seconds
Memory Before: 5,135.852 KB
Memory After: 5,136.281 KB
WHERE templateid IN (62234,62232,55071,57273,57295,62316,0,0,6082,38961,42855,57213,38966,57292,5992,38968,38969,57230,62031,62305,45486,61981,53288,61979,61980,62335,0,0,62315,62276,62001,62002,62004,62005,62228,62347,62329,62279,62280,61828,61827,61831,61422,61391,61420,61659)
1SIMPLEtemplaterangePRIMARYPRIMARY4 43Using where
Time Before: 0.03529 seconds
Time After: 0.03711 seconds
Time Taken: 0.00182 seconds
Memory Before: 5,406.578 KB
Memory After: 5,407.844 KB
Memory Used: 1.266 KB
SET location = '/forums/profile.php?do=switchusercss&explain=1&u=110805', badlocation = 1
WHERE sessionhash = 'ba7fff4c8d66601b301d53cd735f0776'
Time Before: 0.04920 seconds
Time After: 0.04945 seconds
Memory Before: 5,845.109 KB
Memory After: 5,845.328 KB
Page generated in 0.048322916030884 seconds with 9 queries, spending 0.010706186294556 doing MySQL queries and 0.037616729736328 doing PHP things.
