Time Before: 0.00147 seconds
Time After: 0.00199 seconds
Memory Before: 2,056.352 KB
Memory After: 2,081.469 KB
Time Before: 0.00206 seconds
Time After: 0.00242 seconds
Memory Before: 2,081.406 KB
Memory After: 2,082.414 KB
Time Before: 0.00260 seconds
Time After: 0.00276 seconds
Memory Before: 2,082.992 KB
Memory After: 2,083.516 KB
Time Before: 0.00340 seconds
Time After: 0.00630 seconds
Time Taken: 0.00290 seconds
Memory Before: 2,086.141 KB
Memory After: 2,087.078 KB
Memory Used: 0.938 KB
Time Before: 0.00280 seconds
Time After: 0.01107 seconds
Time Taken: 0.00827 seconds
Memory Before: 2,082.766 KB
Memory After: 3,171.813 KB
Memory Used: 1,089.047 KB
Time Before: 0.01300 seconds
Time After: 0.01336 seconds
Memory Before: 3,664.609 KB
Memory After: 3,665.227 KB
Time Before: 0.01583 seconds
Time After: 0.02031 seconds
Time Taken: 0.00448 seconds
Memory Before: 3,676.570 KB
Memory After: 3,676.445 KB
Memory Used: -0.125 KB
Time Before: 0.01245 seconds
Time After: 0.02049 seconds
Time Taken: 0.00804 seconds
Memory Before: 3,656.789 KB
Memory After: 3,806.570 KB
Memory Used: 149.781 KB
Time Before: 0.02737 seconds
Time After: 0.02753 seconds
Memory Before: 4,411.047 KB
Memory After: 4,411.563 KB
Time Before: 0.03033 seconds
Time After: 0.03160 seconds
Memory Before: 4,498.742 KB
Memory After: 4,499.336 KB
Time Before: 0.03646 seconds
Time After: 0.03683 seconds
Memory Before: 5,135.852 KB
Memory After: 5,136.281 KB
Time Before: 0.03952 seconds
Time After: 0.04121 seconds
Time Taken: 0.00169 seconds
Memory Before: 5,406.578 KB
Memory After: 5,407.844 KB
Memory Used: 1.266 KB
UPDATE session SET location = '/forums/profile.php?do=switchusercss&explain=1&u=111157', badlocation = 1 WHERE sessionhash = '0876df9564c01931f09cc799627f41fa'
Time Before: 0.05664 seconds
Time After: 0.05696 seconds
Memory Before: 5,845.109 KB
Memory After: 5,845.328 KB
