Time Before: 0.01760 seconds
Time After: 0.02204 seconds
Time Taken: 0.00445 seconds
Memory Before: 2,056.352 KB
Memory After: 2,081.469 KB
Time Before: 0.02215 seconds
Time After: 0.02261 seconds
Memory Before: 2,081.406 KB
Memory After: 2,082.414 KB
Time Before: 0.02286 seconds
Time After: 0.02303 seconds
Memory Before: 2,082.992 KB
Memory After: 2,083.516 KB
Time Before: 0.02382 seconds
Time After: 0.02691 seconds
Time Taken: 0.00309 seconds
Memory Before: 2,086.141 KB
Memory After: 2,087.078 KB
Memory Used: 0.938 KB
Time Before: 0.02310 seconds
Time After: 0.03124 seconds
Time Taken: 0.00814 seconds
Memory Before: 2,082.766 KB
Memory After: 3,171.813 KB
Memory Used: 1,089.047 KB
Time Before: 0.03807 seconds
Time After: 0.03828 seconds
Memory Before: 3,664.609 KB
Memory After: 3,665.227 KB
Time Before: 0.04077 seconds
Time After: 0.04220 seconds
Memory Before: 3,676.586 KB
Memory After: 3,676.461 KB
Memory Used: -0.125 KB
Time Before: 0.03746 seconds
Time After: 0.04244 seconds
Time Taken: 0.00498 seconds
Memory Before: 3,656.789 KB
Memory After: 3,806.586 KB
Memory Used: 149.797 KB
Time Before: 0.06596 seconds
Time After: 0.06615 seconds
Memory Before: 4,411.078 KB
Memory After: 4,411.594 KB
Time Before: 0.14336 seconds
Time After: 0.14463 seconds
Memory Before: 4,498.773 KB
Memory After: 4,499.367 KB
Time Before: 0.15420 seconds
Time After: 0.15437 seconds
Memory Before: 5,135.875 KB
Memory After: 5,136.305 KB
Time Before: 0.15664 seconds
Time After: 0.15782 seconds
Time Taken: 0.00117 seconds
Memory Before: 5,406.586 KB
Memory After: 5,407.852 KB
Memory Used: 1.266 KB
UPDATE session SET location = '/forums/profile.php?do=switchusercss&explain=1&u=114922', badlocation = 1 WHERE sessionhash = '976fd7bc103f4eb56194add8301aec32'
Time Before: 0.17688 seconds
Time After: 0.17714 seconds
Memory Before: 5,845.055 KB
Memory After: 5,845.273 KB
