Time Before: 0.01287 seconds
Time After: 0.01801 seconds
Time Taken: 0.00514 seconds
Memory Before: 2,056.789 KB
Memory After: 2,081.906 KB
Time Before: 0.01812 seconds
Time After: 0.01853 seconds
Memory Before: 2,081.844 KB
Memory After: 2,082.852 KB
Time Before: 0.01874 seconds
Time After: 0.01892 seconds
Memory Before: 2,083.461 KB
Memory After: 2,083.984 KB
Time Before: 0.01974 seconds
Time After: 0.02292 seconds
Time Taken: 0.00318 seconds
Memory Before: 2,086.609 KB
Memory After: 2,087.547 KB
Memory Used: 0.938 KB
Time Before: 0.01900 seconds
Time After: 0.02833 seconds
Time Taken: 0.00934 seconds
Memory Before: 2,083.203 KB
Memory After: 3,172.195 KB
Memory Used: 1,088.992 KB
Time Before: 0.03451 seconds
Time After: 0.03498 seconds
Memory Before: 3,665.016 KB
Memory After: 3,665.633 KB
Time Before: 0.03664 seconds
Time After: 0.03925 seconds
Time Taken: 0.00261 seconds
Memory Before: 3,676.992 KB
Memory After: 3,676.867 KB
Memory Used: -0.125 KB
Time Before: 0.03370 seconds
Time After: 0.03952 seconds
Time Taken: 0.00582 seconds
Memory Before: 3,657.164 KB
Memory After: 3,806.961 KB
Memory Used: 149.797 KB
Time Before: 0.06450 seconds
Time After: 0.06464 seconds
Memory Before: 4,411.461 KB
Memory After: 4,411.977 KB
Time Before: 0.07500 seconds
Time After: 0.07625 seconds
Memory Before: 4,499.133 KB
Memory After: 4,499.727 KB
Time Before: 0.08360 seconds
Time After: 0.08375 seconds
Memory Before: 5,137.289 KB
Memory After: 5,137.734 KB
Memory Used: 0.445 KB
Time Before: 0.08704 seconds
Time After: 0.08876 seconds
Time Taken: 0.00171 seconds
Memory Before: 5,408.031 KB
Memory After: 5,409.297 KB
Memory Used: 1.266 KB
UPDATE session SET location = '/forums/profile.php?do=switchusercss&explain=1&u=115102', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.10631 seconds
Time After: 0.10656 seconds
Memory Before: 5,846.555 KB
Memory After: 5,846.773 KB
