Time Before: 0.00139 seconds
Time After: 0.00182 seconds
Memory Before: 2,056.352 KB
Memory After: 2,081.469 KB
Time Before: 0.00189 seconds
Time After: 0.00231 seconds
Memory Before: 2,081.406 KB
Memory After: 2,082.414 KB
Time Before: 0.00250 seconds
Time After: 0.00265 seconds
Memory Before: 2,082.992 KB
Memory After: 2,083.516 KB
Time Before: 0.00335 seconds
Time After: 0.00584 seconds
Time Taken: 0.00249 seconds
Memory Before: 2,086.141 KB
Memory After: 2,087.078 KB
Memory Used: 0.938 KB
Time Before: 0.00270 seconds
Time After: 0.00935 seconds
Time Taken: 0.00665 seconds
Memory Before: 2,082.766 KB
Memory After: 3,171.813 KB
Memory Used: 1,089.047 KB
Time Before: 0.01151 seconds
Time After: 0.01196 seconds
Memory Before: 3,664.609 KB
Memory After: 3,665.227 KB
Time Before: 0.01547 seconds
Time After: 0.01683 seconds
Time Taken: 0.00137 seconds
Memory Before: 3,676.570 KB
Memory After: 3,676.445 KB
Memory Used: -0.125 KB
Time Before: 0.01078 seconds
Time After: 0.01702 seconds
Time Taken: 0.00623 seconds
Memory Before: 3,656.789 KB
Memory After: 3,806.570 KB
Memory Used: 149.781 KB
Time Before: 0.02268 seconds
Time After: 0.02281 seconds
Memory Before: 4,411.047 KB
Memory After: 4,411.563 KB
Time Before: 0.02516 seconds
Time After: 0.02702 seconds
Time Taken: 0.00187 seconds
Memory Before: 4,498.742 KB
Memory After: 4,499.336 KB
Time Before: 0.02986 seconds
Time After: 0.02999 seconds
Memory Before: 5,135.852 KB
Memory After: 5,136.281 KB
Time Before: 0.03184 seconds
Time After: 0.03297 seconds
Time Taken: 0.00113 seconds
Memory Before: 5,406.578 KB
Memory After: 5,407.844 KB
Memory Used: 1.266 KB
UPDATE session SET location = '/forums/profile.php?do=switchusercss&explain=1&u=115380', badlocation = 1 WHERE sessionhash = 'f88c536979e48fd20a608e8efaf90f77'
Time Before: 0.04521 seconds
Time After: 0.04550 seconds
Memory Before: 5,845.109 KB
Memory After: 5,845.328 KB
