Time Before: 0.00275 seconds
Time After: 0.00324 seconds
Memory Before: 2,054.688 KB
Memory After: 2,079.805 KB
Time Before: 0.00331 seconds
Time After: 0.00375 seconds
Memory Before: 2,079.742 KB
Memory After: 2,080.750 KB
Time Before: 0.00404 seconds
Time After: 0.00417 seconds
Memory Before: 2,081.359 KB
Memory After: 2,081.883 KB
WHERE title IN ('smiliecache','bbcodecache','banemail','ranks','noavatarperms','navdata','options','bitfields','attachmentcache','forumcache','usergroupcache','stylecache','languagecache','products','pluginlist','cron','profilefield','loadcache','noticecache','activitystream','routes')
1SIMPLEdatastorerangePRIMARYPRIMARY52 21Using where
Time Before: 0.00515 seconds
Time After: 0.00945 seconds
Time Taken: 0.00430 seconds
Memory Before: 2,084.508 KB
Memory After: 2,085.445 KB
Memory Used: 0.938 KB
Time Before: 0.00425 seconds
Time After: 0.01509 seconds
Time Taken: 0.01084 seconds
Memory Before: 2,081.102 KB
Memory After: 3,170.094 KB
Memory Used: 1,088.992 KB
Time Before: 0.01768 seconds
Time After: 0.01815 seconds
Memory Before: 3,662.922 KB
Memory After: 3,663.539 KB
			phrasegroup_timezone AS phrasegroup_timezone,
			phrasegroup_cprofilefield AS phrasegroup_cprofilefield,
			phrasegroup_cppermission AS phrasegroup_cppermission,
Time Before: 0.02083 seconds
Time After: 0.02594 seconds
Time Taken: 0.00510 seconds
Memory Before: 3,675.000 KB
Memory After: 3,674.875 KB
Memory Used: -0.125 KB
Time Before: 0.01689 seconds
Time After: 0.02624 seconds
Time Taken: 0.00935 seconds
Memory Before: 3,655.070 KB
Memory After: 3,805.297 KB
Memory Used: 150.227 KB
Time Before: 0.03477 seconds
Time After: 0.03499 seconds
Memory Before: 4,409.797 KB
Memory After: 4,410.313 KB
Time Before: 0.03717 seconds
Time After: 0.04026 seconds
Time Taken: 0.00310 seconds
Memory Before: 4,497.617 KB
Memory After: 4,498.211 KB
End call of global.php: 0.042248010635376
Time Before: 0.04349 seconds
Time After: 0.04366 seconds
Memory Before: 5,135.758 KB
Memory After: 5,136.188 KB
WHERE templateid IN (62234,62232,55071,57273,57295,62316,0,0,6082,38961,42855,57213,38966,57292,5992,38968,38969,57230,62031,62305,45486,61981,53288,61979,61980,62335,0,0,62315,62276,62001,62002,62004,62005,62228,62347,62329,62279,62280,61828,61827,61831,61422,61391,61420,61659)
1SIMPLEtemplaterangePRIMARYPRIMARY4 43Using where
Time Before: 0.04561 seconds
Time After: 0.04749 seconds
Time Taken: 0.00189 seconds
Memory Before: 5,406.406 KB
Memory After: 5,407.672 KB
Memory Used: 1.266 KB
SET lastactivity = 1787721998, location = '/forums/profile.php?do=switchusercss&explain=1&u=115393', badlocation = 1
WHERE sessionhash = '134a2328b51cb33f023ae60304ac6c97'
Time Before: 0.06192 seconds
Time After: 0.06225 seconds
Memory Before: 5,857.828 KB
Memory After: 5,858.031 KB
Memory Used: 0.203 KB
Page generated in 0.060418844223022 seconds with 9 queries, spending 0.0161452293396 doing MySQL queries and 0.044273614883423 doing PHP things.
