Time Before: 0.02196 seconds
Time After: 0.02768 seconds
Time Taken: 0.00572 seconds
Memory Before: 2,056.789 KB
Memory After: 2,081.906 KB
Time Before: 0.02776 seconds
Time After: 0.02822 seconds
Memory Before: 2,081.844 KB
Memory After: 2,082.852 KB
Time Before: 0.02848 seconds
Time After: 0.02860 seconds
Memory Before: 2,083.461 KB
Memory After: 2,083.984 KB
WHERE title IN ('smiliecache','bbcodecache','banemail','ranks','noavatarperms','navdata','options','bitfields','attachmentcache','forumcache','usergroupcache','stylecache','languagecache','products','pluginlist','cron','profilefield','loadcache','noticecache','activitystream','routes')
1SIMPLEdatastorerangePRIMARYPRIMARY52 21Using where
Time Before: 0.02944 seconds
Time After: 0.03179 seconds
Time Taken: 0.00235 seconds
Memory Before: 2,086.609 KB
Memory After: 2,087.547 KB
Memory Used: 0.938 KB
Time Before: 0.02868 seconds
Time After: 0.03579 seconds
Time Taken: 0.00711 seconds
Memory Before: 2,083.203 KB
Memory After: 3,172.195 KB
Memory Used: 1,088.992 KB
Time Before: 0.04481 seconds
Time After: 0.04527 seconds
Memory Before: 3,665.016 KB
Memory After: 3,665.633 KB
			phrasegroup_timezone AS phrasegroup_timezone,
			phrasegroup_cprofilefield AS phrasegroup_cprofilefield,
			phrasegroup_cppermission AS phrasegroup_cppermission,
Time Before: 0.04859 seconds
Time After: 0.05135 seconds
Time Taken: 0.00276 seconds
Memory Before: 3,676.977 KB
Memory After: 3,676.852 KB
Memory Used: -0.125 KB
Time Before: 0.04419 seconds
Time After: 0.05158 seconds
Time Taken: 0.00740 seconds
Memory Before: 3,657.164 KB
Memory After: 3,806.945 KB
Memory Used: 149.781 KB
Time Before: 0.09150 seconds
Time After: 0.09161 seconds
Memory Before: 4,411.414 KB
Memory After: 4,411.930 KB
Time Before: 0.10300 seconds
Time After: 0.10423 seconds
Memory Before: 4,499.086 KB
Memory After: 4,499.680 KB
End call of global.php: 0.10607600212097
Time Before: 0.11417 seconds
Time After: 0.11432 seconds
Memory Before: 5,137.227 KB
Memory After: 5,137.672 KB
Memory Used: 0.445 KB
WHERE templateid IN (62234,62232,55071,57273,57295,62316,0,0,6082,38961,42855,57213,38966,57292,5992,38968,38969,57230,62031,62305,45486,61981,53288,61979,61980,62335,0,0,62315,62276,62001,62002,62004,62005,62228,62347,62329,62279,62280,61828,61827,61831,61422,61391,61420,61659)
1SIMPLEtemplaterangePRIMARYPRIMARY4 43Using where
Time Before: 0.11671 seconds
Time After: 0.11785 seconds
Time Taken: 0.00115 seconds
Memory Before: 5,407.891 KB
Memory After: 5,409.156 KB
Memory Used: 1.266 KB
SET location = '/forums/profile.php?do=switchusercss&explain=1&u=115493', badlocation = 1
WHERE sessionhash = '134a2328b51cb33f023ae60304ac6c97'
Time Before: 0.13690 seconds
Time After: 0.13716 seconds
Memory Before: 5,846.484 KB
Memory After: 5,846.703 KB
Page generated in 0.13583493232727 seconds with 9 queries, spending 0.0090427398681641 doing MySQL queries and 0.12679219245911 doing PHP things.
