Time Before: 0.00146 seconds
Time After: 0.00195 seconds
Memory Before: 2,056.789 KB
Memory After: 2,081.906 KB
Time Before: 0.00202 seconds
Time After: 0.00264 seconds
Time Taken: 0.00062 seconds
Memory Before: 2,081.844 KB
Memory After: 2,082.852 KB
Time Before: 0.00293 seconds
Time After: 0.00304 seconds
Memory Before: 2,083.461 KB
Memory After: 2,083.984 KB
WHERE title IN ('smiliecache','bbcodecache','banemail','ranks','noavatarperms','navdata','options','bitfields','attachmentcache','forumcache','usergroupcache','stylecache','languagecache','products','pluginlist','cron','profilefield','loadcache','noticecache','activitystream','routes')
1SIMPLEdatastorerangePRIMARYPRIMARY52 21Using where
Time Before: 0.00374 seconds
Time After: 0.00684 seconds
Time Taken: 0.00310 seconds
Memory Before: 2,086.609 KB
Memory After: 2,087.547 KB
Memory Used: 0.938 KB
Time Before: 0.00309 seconds
Time After: 0.01026 seconds
Time Taken: 0.00717 seconds
Memory Before: 2,083.203 KB
Memory After: 3,172.195 KB
Memory Used: 1,088.992 KB
Time Before: 0.01199 seconds
Time After: 0.01225 seconds
Memory Before: 3,665.016 KB
Memory After: 3,665.633 KB
			phrasegroup_timezone AS phrasegroup_timezone,
			phrasegroup_cprofilefield AS phrasegroup_cprofilefield,
			phrasegroup_cppermission AS phrasegroup_cppermission,
Time Before: 0.01456 seconds
Time After: 0.01780 seconds
Time Taken: 0.00324 seconds
Memory Before: 3,677.094 KB
Memory After: 3,676.969 KB
Memory Used: -0.125 KB
Time Before: 0.01140 seconds
Time After: 0.01799 seconds
Time Taken: 0.00659 seconds
Memory Before: 3,657.164 KB
Memory After: 3,807.063 KB
Memory Used: 149.898 KB
Time Before: 0.02332 seconds
Time After: 0.02355 seconds
Memory Before: 4,411.516 KB
Memory After: 4,412.031 KB
Time Before: 1.60788 seconds
Time After: 1.61001 seconds
Time Taken: 0.00212 seconds
Memory Before: 4,499.211 KB
Memory After: 4,499.805 KB
End call of global.php: 1.6117849349976
Time Before: 1.61283 seconds
Time After: 1.61302 seconds
Memory Before: 5,137.398 KB
Memory After: 5,137.844 KB
Memory Used: 0.445 KB
WHERE templateid IN (62234,62232,55071,57273,57295,62316,0,0,6082,38961,42855,57213,38966,57292,5992,38968,38969,57230,62031,62305,45486,61981,53288,61979,61980,62335,0,0,62315,62276,62001,62002,62004,62005,62228,62347,62329,62279,62280,61828,61827,61831,61422,61391,61420,61659)
1SIMPLEtemplaterangePRIMARYPRIMARY4 43Using where
Time Before: 1.61497 seconds
Time After: 1.61650 seconds
Time Taken: 0.00153 seconds
Memory Before: 5,408.141 KB
Memory After: 5,409.406 KB
Memory Used: 1.266 KB
SET lastactivity = 1773336537, location = '/forums/profile.php?do=switchusercss&explain=1&u=115897'
Time Before: 1.62904 seconds
Time After: 1.62928 seconds
Memory Before: 5,846.664 KB
Memory After: 5,846.883 KB
Page generated in 1.6281430721283 seconds with 9 queries, spending 0.011648654937744 doing MySQL queries and 1.6164944171906 doing PHP things.
