Time Before: 0.00141 seconds
Time After: 0.00203 seconds
Time Taken: 0.00062 seconds
Memory Before: 2,056.352 KB
Memory After: 2,081.469 KB
Time Before: 0.00209 seconds
Time After: 0.00275 seconds
Time Taken: 0.00066 seconds
Memory Before: 2,081.406 KB
Memory After: 2,082.414 KB
Time Before: 0.00298 seconds
Time After: 0.00314 seconds
Memory Before: 2,082.992 KB
Memory After: 2,083.516 KB
Time Before: 0.00383 seconds
Time After: 0.00690 seconds
Time Taken: 0.00308 seconds
Memory Before: 2,086.141 KB
Memory After: 2,087.078 KB
Memory Used: 0.938 KB
Time Before: 0.00320 seconds
Time After: 0.01051 seconds
Time Taken: 0.00732 seconds
Memory Before: 2,082.766 KB
Memory After: 3,171.813 KB
Memory Used: 1,089.047 KB
Time Before: 0.01227 seconds
Time After: 0.01246 seconds
Memory Before: 3,664.609 KB
Memory After: 3,665.227 KB
Time Before: 0.01503 seconds
Time After: 0.01867 seconds
Time Taken: 0.00364 seconds
Memory Before: 3,676.688 KB
Memory After: 3,676.563 KB
Memory Used: -0.125 KB
Time Before: 0.01172 seconds
Time After: 0.01884 seconds
Time Taken: 0.00711 seconds
Memory Before: 3,656.789 KB
Memory After: 3,806.688 KB
Memory Used: 149.898 KB
Time Before: 0.02403 seconds
Time After: 0.02415 seconds
Memory Before: 4,411.117 KB
Memory After: 4,411.633 KB
Time Before: 0.02612 seconds
Time After: 0.02735 seconds
Memory Before: 4,498.789 KB
Memory After: 4,499.383 KB
Time Before: 0.03016 seconds
Time After: 0.03083 seconds
Time Taken: 0.00067 seconds
Memory Before: 5,135.891 KB
Memory After: 5,136.320 KB
Time Before: 0.03267 seconds
Time After: 0.03440 seconds
Time Taken: 0.00173 seconds
Memory Before: 5,406.914 KB
Memory After: 5,408.180 KB
Memory Used: 1.266 KB
UPDATE session SET lastactivity = 1782803384, location = '/forums/profile.php?do=switchusercss&explain=1&u=117636', badlocation = 1 WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.04650 seconds
Time After: 0.04685 seconds
Memory Before: 5,845.406 KB
Memory After: 5,845.609 KB
Memory Used: 0.203 KB
