Time Before: 0.01391 seconds
Time After: 0.01994 seconds
Time Taken: 0.00603 seconds
Memory Before: 2,056.352 KB
Memory After: 2,081.469 KB
Time Before: 0.02002 seconds
Time After: 0.02039 seconds
Memory Before: 2,081.406 KB
Memory After: 2,082.414 KB
Time Before: 0.02063 seconds
Time After: 0.02077 seconds
Memory Before: 2,082.992 KB
Memory After: 2,083.516 KB
Time Before: 0.02152 seconds
Time After: 0.02374 seconds
Time Taken: 0.00222 seconds
Memory Before: 2,086.141 KB
Memory After: 2,087.078 KB
Memory Used: 0.938 KB
Time Before: 0.02083 seconds
Time After: 0.02780 seconds
Time Taken: 0.00697 seconds
Memory Before: 2,082.766 KB
Memory After: 3,171.813 KB
Memory Used: 1,089.047 KB
Time Before: 0.03246 seconds
Time After: 0.03284 seconds
Memory Before: 3,664.609 KB
Memory After: 3,665.227 KB
Time Before: 0.03527 seconds
Time After: 0.03664 seconds
Time Taken: 0.00137 seconds
Memory Before: 3,676.688 KB
Memory After: 3,676.563 KB
Memory Used: -0.125 KB
Time Before: 0.03173 seconds
Time After: 0.03687 seconds
Time Taken: 0.00514 seconds
Memory Before: 3,656.789 KB
Memory After: 3,806.688 KB
Memory Used: 149.898 KB
Time Before: 0.05527 seconds
Time After: 0.05541 seconds
Memory Before: 4,411.117 KB
Memory After: 4,411.633 KB
Time Before: 0.06964 seconds
Time After: 0.07091 seconds
Memory Before: 4,498.789 KB
Memory After: 4,499.383 KB
Time Before: 0.08225 seconds
Time After: 0.08241 seconds
Memory Before: 5,135.891 KB
Memory After: 5,136.320 KB
Time Before: 0.08497 seconds
Time After: 0.08666 seconds
Time Taken: 0.00169 seconds
Memory Before: 5,406.914 KB
Memory After: 5,408.180 KB
Memory Used: 1.266 KB
UPDATE session SET lastactivity = 1787621923, location = '/forums/profile.php?do=switchusercss&explain=1&u=120532', badlocation = 1 WHERE sessionhash = 'ba7fff4c8d66601b301d53cd735f0776'
Time Before: 0.10482 seconds
Time After: 0.10511 seconds
Memory Before: 5,845.406 KB
Memory After: 5,845.609 KB
Memory Used: 0.203 KB
