Time Before: 0.02598 seconds
Time After: 0.03597 seconds
Time Taken: 0.00999 seconds
Memory Before: 2,056.352 KB
Memory After: 2,081.469 KB
Time Before: 0.03606 seconds
Time After: 0.03648 seconds
Memory Before: 2,081.406 KB
Memory After: 2,082.414 KB
Time Before: 0.03670 seconds
Time After: 0.03686 seconds
Memory Before: 2,082.992 KB
Memory After: 2,083.516 KB
WHERE title IN ('smiliecache','bbcodecache','banemail','ranks','noavatarperms','navdata','options','bitfields','attachmentcache','forumcache','usergroupcache','stylecache','languagecache','products','pluginlist','cron','profilefield','loadcache','noticecache','activitystream','routes')
1SIMPLEdatastorerangePRIMARYPRIMARY52 21Using where
Time Before: 0.03769 seconds
Time After: 0.04094 seconds
Time Taken: 0.00325 seconds
Memory Before: 2,086.141 KB
Memory After: 2,087.078 KB
Memory Used: 0.938 KB
Time Before: 0.03696 seconds
Time After: 0.04514 seconds
Time Taken: 0.00818 seconds
Memory Before: 2,082.766 KB
Memory After: 3,171.813 KB
Memory Used: 1,089.047 KB
Time Before: 0.05446 seconds
Time After: 0.05487 seconds
Memory Before: 3,664.609 KB
Memory After: 3,665.227 KB
			phrasegroup_timezone AS phrasegroup_timezone,
			phrasegroup_cprofilefield AS phrasegroup_cprofilefield,
			phrasegroup_cppermission AS phrasegroup_cppermission,
Time Before: 0.05748 seconds
Time After: 0.06058 seconds
Time Taken: 0.00310 seconds
Memory Before: 3,676.703 KB
Memory After: 3,676.578 KB
Memory Used: -0.125 KB
Time Before: 0.05364 seconds
Time After: 0.06086 seconds
Time Taken: 0.00723 seconds
Memory Before: 3,656.789 KB
Memory After: 3,806.703 KB
Memory Used: 149.914 KB
Time Before: 0.10353 seconds
Time After: 0.10372 seconds
Memory Before: 4,411.188 KB
Memory After: 4,411.703 KB
Time Before: 0.20693 seconds
Time After: 0.20821 seconds
Memory Before: 4,498.883 KB
Memory After: 4,499.477 KB
End call of global.php: 0.21112394332886
Time Before: 0.21898 seconds
Time After: 0.21916 seconds
Memory Before: 5,135.992 KB
Memory After: 5,136.422 KB
WHERE templateid IN (62234,62232,55071,57273,57295,62316,0,0,6082,38961,42855,57213,38966,57292,5992,38968,38969,57230,62031,62305,45486,61981,53288,61979,61980,62335,0,0,62315,62276,62001,62002,62004,62005,62228,62347,62329,62279,62280,61828,61827,61831,61422,61391,61420,61659)
1SIMPLEtemplaterangePRIMARYPRIMARY4 43Using where
Time Before: 0.22196 seconds
Time After: 0.22343 seconds
Memory Before: 5,407.008 KB
Memory After: 5,408.273 KB
Memory Used: 1.266 KB
SET lastactivity = 1785328048, location = '/forums/profile.php?do=switchusercss&explain=1&u=1630', badlocation = 1
Time Before: 0.24200 seconds
Time After: 0.24224 seconds
Memory Before: 5,845.617 KB
Memory After: 5,845.820 KB
Memory Used: 0.203 KB
Page generated in 0.24099683761597 seconds with 9 queries, spending 0.01071834564209 doing MySQL queries and 0.23027849197388 doing PHP things.
