Time Before: 0.00180 seconds
Time After: 0.00249 seconds
Time Taken: 0.00069 seconds
Memory Before: 2,056.789 KB
Memory After: 2,081.906 KB
Time Before: 0.00260 seconds
Time After: 0.00305 seconds
Memory Before: 2,081.844 KB
Memory After: 2,082.852 KB
Time Before: 0.00331 seconds
Time After: 0.00344 seconds
Memory Before: 2,083.461 KB
Memory After: 2,083.984 KB
Time Before: 0.00417 seconds
Time After: 0.00925 seconds
Time Taken: 0.00508 seconds
Memory Before: 2,086.609 KB
Memory After: 2,087.547 KB
Memory Used: 0.938 KB
Time Before: 0.00351 seconds
Time After: 0.01275 seconds
Time Taken: 0.00924 seconds
Memory Before: 2,083.203 KB
Memory After: 3,172.195 KB
Memory Used: 1,088.992 KB
Time Before: 0.01473 seconds
Time After: 0.01512 seconds
Memory Before: 3,665.016 KB
Memory After: 3,665.633 KB
Time Before: 0.01656 seconds
Time After: 0.02017 seconds
Time Taken: 0.00361 seconds
Memory Before: 3,676.992 KB
Memory After: 3,676.867 KB
Memory Used: -0.125 KB
Time Before: 0.01415 seconds
Time After: 0.02039 seconds
Time Taken: 0.00624 seconds
Memory Before: 3,657.164 KB
Memory After: 3,806.961 KB
Memory Used: 149.797 KB
Time Before: 0.02745 seconds
Time After: 0.02783 seconds
Memory Before: 4,411.461 KB
Memory After: 4,411.977 KB
Time Before: 0.03012 seconds
Time After: 0.03147 seconds
Time Taken: 0.00135 seconds
Memory Before: 4,499.133 KB
Memory After: 4,499.727 KB
Time Before: 0.03589 seconds
Time After: 0.03607 seconds
Memory Before: 5,137.289 KB
Memory After: 5,137.734 KB
Memory Used: 0.445 KB
Time Before: 0.03889 seconds
Time After: 0.04035 seconds
Memory Before: 5,408.031 KB
Memory After: 5,409.297 KB
Memory Used: 1.266 KB
UPDATE session SET location = '/forums/profile.php?do=switchusercss&explain=1&u=2403', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05287 seconds
Time After: 0.05314 seconds
Memory Before: 5,846.484 KB
Memory After: 5,846.703 KB
