Time Before: 0.02338 seconds
Time After: 0.02980 seconds
Time Taken: 0.00642 seconds
Memory Before: 2,056.352 KB
Memory After: 2,081.469 KB
Time Before: 0.02989 seconds
Time After: 0.03027 seconds
Memory Before: 2,081.406 KB
Memory After: 2,082.414 KB
Time Before: 0.03050 seconds
Time After: 0.03064 seconds
Memory Before: 2,082.992 KB
Memory After: 2,083.516 KB
Time Before: 0.03141 seconds
Time After: 0.03389 seconds
Time Taken: 0.00247 seconds
Memory Before: 2,086.141 KB
Memory After: 2,087.078 KB
Memory Used: 0.938 KB
Time Before: 0.03072 seconds
Time After: 0.03842 seconds
Time Taken: 0.00770 seconds
Memory Before: 2,082.766 KB
Memory After: 3,171.813 KB
Memory Used: 1,089.047 KB
Time Before: 0.04956 seconds
Time After: 0.04983 seconds
Memory Before: 3,664.609 KB
Memory After: 3,665.227 KB
Time Before: 0.05179 seconds
Time After: 0.05460 seconds
Time Taken: 0.00281 seconds
Memory Before: 3,676.703 KB
Memory After: 3,676.578 KB
Memory Used: -0.125 KB
Time Before: 0.04878 seconds
Time After: 0.05486 seconds
Time Taken: 0.00608 seconds
Memory Before: 3,656.789 KB
Memory After: 3,806.703 KB
Memory Used: 149.914 KB
Time Before: 0.08433 seconds
Time After: 0.08460 seconds
Memory Before: 4,411.188 KB
Memory After: 4,411.703 KB
Time Before: 0.10672 seconds
Time After: 0.10796 seconds
Memory Before: 4,498.883 KB
Memory After: 4,499.477 KB
Time Before: 0.12112 seconds
Time After: 0.12135 seconds
Memory Before: 5,135.992 KB
Memory After: 5,136.422 KB
Time Before: 0.12432 seconds
Time After: 0.12638 seconds
Time Taken: 0.00206 seconds
Memory Before: 5,407.008 KB
Memory After: 5,408.273 KB
Memory Used: 1.266 KB
UPDATE session SET lastactivity = 1789101833, location = '/forums/profile.php?do=switchusercss&explain=1&u=2547', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.14626 seconds
Time After: 0.14652 seconds
Memory Before: 5,845.617 KB
Memory After: 5,845.820 KB
Memory Used: 0.203 KB
