Time Before: 0.01851 seconds
Time After: 0.02764 seconds
Time Taken: 0.00914 seconds
Memory Before: 2,056.789 KB
Memory After: 2,081.906 KB
Time Before: 0.02776 seconds
Time After: 0.02846 seconds
Time Taken: 0.00071 seconds
Memory Before: 2,081.844 KB
Memory After: 2,082.852 KB
Time Before: 0.02883 seconds
Time After: 0.02911 seconds
Memory Before: 2,083.461 KB
Memory After: 2,083.984 KB
Time Before: 0.02998 seconds
Time After: 0.03200 seconds
Time Taken: 0.00202 seconds
Memory Before: 2,086.609 KB
Memory After: 2,087.547 KB
Memory Used: 0.938 KB
Time Before: 0.02921 seconds
Time After: 0.03634 seconds
Time Taken: 0.00713 seconds
Memory Before: 2,083.203 KB
Memory After: 3,172.195 KB
Memory Used: 1,088.992 KB
Time Before: 0.04692 seconds
Time After: 0.04735 seconds
Memory Before: 3,665.016 KB
Memory After: 3,665.633 KB
Time Before: 0.05078 seconds
Time After: 0.05216 seconds
Time Taken: 0.00139 seconds
Memory Before: 3,677.109 KB
Memory After: 3,676.984 KB
Memory Used: -0.125 KB
Time Before: 0.04613 seconds
Time After: 0.05245 seconds
Time Taken: 0.00632 seconds
Memory Before: 3,657.164 KB
Memory After: 3,807.078 KB
Memory Used: 149.914 KB
Time Before: 0.07779 seconds
Time After: 0.07793 seconds
Memory Before: 4,411.609 KB
Memory After: 4,412.125 KB
Time Before: 0.09657 seconds
Time After: 0.09780 seconds
Memory Before: 4,499.281 KB
Memory After: 4,499.875 KB
Time Before: 0.11043 seconds
Time After: 0.11064 seconds
Memory Before: 5,137.453 KB
Memory After: 5,137.898 KB
Memory Used: 0.445 KB
Time Before: 0.11341 seconds
Time After: 0.11460 seconds
Memory Before: 5,408.203 KB
Memory After: 5,409.469 KB
Memory Used: 1.266 KB
UPDATE session SET lastactivity = 1787723828, location = '/forums/profile.php?do=switchusercss&explain=1&u=36705', badlocation = 1 WHERE sessionhash = '134a2328b51cb33f023ae60304ac6c97'
Time Before: 0.13326 seconds
Time After: 0.13362 seconds
Memory Before: 5,846.906 KB
Memory After: 5,847.109 KB
Memory Used: 0.203 KB
