Time Before: 0.02219 seconds
Time After: 0.02957 seconds
Time Taken: 0.00738 seconds
Memory Before: 2,056.352 KB
Memory After: 2,081.469 KB
Time Before: 0.02967 seconds
Time After: 0.03008 seconds
Memory Before: 2,081.406 KB
Memory After: 2,082.414 KB
Time Before: 0.03031 seconds
Time After: 0.03042 seconds
Memory Before: 2,082.992 KB
Memory After: 2,083.516 KB
Time Before: 0.03126 seconds
Time After: 0.03394 seconds
Time Taken: 0.00268 seconds
Memory Before: 2,086.141 KB
Memory After: 2,087.078 KB
Memory Used: 0.938 KB
Time Before: 0.03047 seconds
Time After: 0.03874 seconds
Time Taken: 0.00827 seconds
Memory Before: 2,082.766 KB
Memory After: 3,171.813 KB
Memory Used: 1,089.047 KB
Time Before: 0.04893 seconds
Time After: 0.04936 seconds
Memory Before: 3,664.609 KB
Memory After: 3,665.227 KB
Time Before: 0.05248 seconds
Time After: 0.05545 seconds
Time Taken: 0.00297 seconds
Memory Before: 3,676.570 KB
Memory After: 3,676.445 KB
Memory Used: -0.125 KB
Time Before: 0.04826 seconds
Time After: 0.05572 seconds
Time Taken: 0.00746 seconds
Memory Before: 3,656.789 KB
Memory After: 3,806.570 KB
Memory Used: 149.781 KB
Time Before: 0.08030 seconds
Time After: 0.08047 seconds
Memory Before: 4,411.047 KB
Memory After: 4,411.563 KB
Time Before: 0.09758 seconds
Time After: 0.09907 seconds
Memory Before: 4,498.742 KB
Memory After: 4,499.336 KB
Time Before: 0.10648 seconds
Time After: 0.10667 seconds
Memory Before: 5,135.852 KB
Memory After: 5,136.281 KB
Time Before: 0.10891 seconds
Time After: 0.11056 seconds
Time Taken: 0.00164 seconds
Memory Before: 5,406.578 KB
Memory After: 5,407.844 KB
Memory Used: 1.266 KB
UPDATE session SET location = '/forums/profile.php?do=switchusercss&explain=1&u=3992', badlocation = 1 WHERE sessionhash = '38fd9ff025e0a699b569c7ae25ea8117'
Time Before: 0.12905 seconds
Time After: 0.12950 seconds
Memory Before: 5,845.039 KB
Memory After: 5,845.258 KB
