Time Before: 0.00148 seconds
Time After: 0.00191 seconds
Memory Before: 2,056.789 KB
Memory After: 2,081.906 KB
Time Before: 0.00199 seconds
Time After: 0.00242 seconds
Memory Before: 2,081.844 KB
Memory After: 2,082.852 KB
Time Before: 0.00262 seconds
Time After: 0.00273 seconds
Memory Before: 2,083.461 KB
Memory After: 2,083.984 KB
Time Before: 0.00349 seconds
Time After: 0.00672 seconds
Time Taken: 0.00323 seconds
Memory Before: 2,086.609 KB
Memory After: 2,087.547 KB
Memory Used: 0.938 KB
Time Before: 0.00278 seconds
Time After: 0.01062 seconds
Time Taken: 0.00785 seconds
Memory Before: 2,083.203 KB
Memory After: 3,172.195 KB
Memory Used: 1,088.992 KB
Time Before: 0.01251 seconds
Time After: 0.01291 seconds
Memory Before: 3,665.016 KB
Memory After: 3,665.633 KB
Time Before: 0.01551 seconds
Time After: 0.01821 seconds
Time Taken: 0.00271 seconds
Memory Before: 3,677.094 KB
Memory After: 3,676.969 KB
Memory Used: -0.125 KB
Time Before: 0.01198 seconds
Time After: 0.01846 seconds
Time Taken: 0.00647 seconds
Memory Before: 3,657.164 KB
Memory After: 3,807.063 KB
Memory Used: 149.898 KB
Time Before: 0.02455 seconds
Time After: 0.02495 seconds
Memory Before: 4,411.516 KB
Memory After: 4,412.031 KB
Time Before: 0.02708 seconds
Time After: 0.02832 seconds
Memory Before: 4,499.211 KB
Memory After: 4,499.805 KB
Time Before: 0.03153 seconds
Time After: 0.03165 seconds
Memory Before: 5,137.398 KB
Memory After: 5,137.844 KB
Memory Used: 0.445 KB
Time Before: 0.03359 seconds
Time After: 0.03502 seconds
Memory Before: 5,408.141 KB
Memory After: 5,409.406 KB
Memory Used: 1.266 KB
UPDATE session SET lastactivity = 1788998840, location = '/forums/profile.php?do=switchusercss&explain=1&u=4248', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04957 seconds
Time After: 0.04989 seconds
Memory Before: 5,846.859 KB
Memory After: 5,847.063 KB
Memory Used: 0.203 KB
