Time Before: 0.00608 seconds
Time After: 0.00964 seconds
Time Taken: 0.00356 seconds
Memory Before: 2,056.789 KB
Memory After: 2,081.906 KB
Time Before: 0.00976 seconds
Time After: 0.01035 seconds
Time Taken: 0.00059 seconds
Memory Before: 2,081.844 KB
Memory After: 2,082.852 KB
Time Before: 0.01059 seconds
Time After: 0.01071 seconds
Memory Before: 2,083.461 KB
Memory After: 2,083.984 KB
Time Before: 0.01144 seconds
Time After: 0.01371 seconds
Time Taken: 0.00227 seconds
Memory Before: 2,086.609 KB
Memory After: 2,087.547 KB
Memory Used: 0.938 KB
Time Before: 0.01078 seconds
Time After: 0.01712 seconds
Time Taken: 0.00634 seconds
Memory Before: 2,083.203 KB
Memory After: 3,172.195 KB
Memory Used: 1,088.992 KB
Time Before: 0.02158 seconds
Time After: 0.02190 seconds
Memory Before: 3,665.016 KB
Memory After: 3,665.633 KB
Time Before: 0.02358 seconds
Time After: 0.02598 seconds
Time Taken: 0.00240 seconds
Memory Before: 3,677.109 KB
Memory After: 3,676.984 KB
Memory Used: -0.125 KB
Time Before: 0.02104 seconds
Time After: 0.02621 seconds
Time Taken: 0.00518 seconds
Memory Before: 3,657.164 KB
Memory After: 3,807.078 KB
Memory Used: 149.914 KB
Time Before: 0.03746 seconds
Time After: 0.03772 seconds
Memory Before: 4,411.609 KB
Memory After: 4,412.125 KB
Time Before: 0.04457 seconds
Time After: 0.04649 seconds
Time Taken: 0.00191 seconds
Memory Before: 4,499.281 KB
Memory After: 4,499.875 KB
Time Before: 0.05370 seconds
Time After: 0.05386 seconds
Memory Before: 5,137.453 KB
Memory After: 5,137.898 KB
Memory Used: 0.445 KB
Time Before: 0.05639 seconds
Time After: 0.05788 seconds
Time Taken: 0.00150 seconds
Memory Before: 5,408.203 KB
Memory After: 5,409.469 KB
Memory Used: 1.266 KB
UPDATE session SET lastactivity = 1789240813, location = '/forums/profile.php?do=switchusercss&explain=1&u=49991', badlocation = 1 WHERE sessionhash = '38fd9ff025e0a699b569c7ae25ea8117'
Time Before: 0.07431 seconds
Time After: 0.07453 seconds
Memory Before: 5,846.906 KB
Memory After: 5,847.109 KB
Memory Used: 0.203 KB
