Time Before: 0.01831 seconds
Time After: 0.02671 seconds
Time Taken: 0.00840 seconds
Memory Before: 2,054.250 KB
Memory After: 2,079.367 KB
Time Before: 0.02681 seconds
Time After: 0.02731 seconds
Memory Before: 2,079.305 KB
Memory After: 2,080.313 KB
Time Before: 0.02751 seconds
Time After: 0.02766 seconds
Memory Before: 2,080.891 KB
Memory After: 2,081.414 KB
WHERE title IN ('smiliecache','bbcodecache','banemail','ranks','noavatarperms','navdata','options','bitfields','attachmentcache','forumcache','usergroupcache','stylecache','languagecache','products','pluginlist','cron','profilefield','loadcache','noticecache','activitystream','routes')
1SIMPLEdatastorerangePRIMARYPRIMARY52 21Using where
Time Before: 0.02850 seconds
Time After: 0.03155 seconds
Time Taken: 0.00305 seconds
Memory Before: 2,084.039 KB
Memory After: 2,084.977 KB
Memory Used: 0.938 KB
Time Before: 0.02771 seconds
Time After: 0.03652 seconds
Time Taken: 0.00881 seconds
Memory Before: 2,080.664 KB
Memory After: 3,169.680 KB
Memory Used: 1,089.016 KB
Time Before: 0.04432 seconds
Time After: 0.04475 seconds
Memory Before: 3,662.438 KB
Memory After: 3,663.055 KB
			phrasegroup_timezone AS phrasegroup_timezone,
			phrasegroup_cprofilefield AS phrasegroup_cprofilefield,
			phrasegroup_cppermission AS phrasegroup_cppermission,
Time Before: 0.04810 seconds
Time After: 0.05159 seconds
Time Taken: 0.00349 seconds
Memory Before: 3,674.516 KB
Memory After: 3,674.391 KB
Memory Used: -0.125 KB
Time Before: 0.04317 seconds
Time After: 0.05185 seconds
Time Taken: 0.00868 seconds
Memory Before: 3,654.617 KB
Memory After: 3,804.867 KB
Memory Used: 150.250 KB
Time Before: 0.07494 seconds
Time After: 0.07509 seconds
Memory Before: 4,409.273 KB
Memory After: 4,409.789 KB
Time Before: 0.09351 seconds
Time After: 0.09486 seconds
Time Taken: 0.00135 seconds
Memory Before: 4,497.063 KB
Memory After: 4,497.656 KB
End call of global.php: 0.097024917602539
Time Before: 0.10678 seconds
Time After: 0.10696 seconds
Memory Before: 5,134.172 KB
Memory After: 5,134.602 KB
WHERE templateid IN (62234,62232,55071,57273,57295,62316,0,0,6082,38961,42855,57213,38966,57292,5992,38968,38969,57230,62031,62305,45486,61981,53288,61979,61980,62335,0,0,62315,62276,62001,62002,62004,62005,62228,62347,62329,62279,62280,61828,61827,61831,61422,61391,61420,61659)
1SIMPLEtemplaterangePRIMARYPRIMARY4 43Using where
Time Before: 0.11046 seconds
Time After: 0.11289 seconds
Time Taken: 0.00243 seconds
Memory Before: 5,405.250 KB
Memory After: 5,406.516 KB
Memory Used: 1.266 KB
SET lastactivity = 1787731774, location = '/forums/profile.php?do=switchusercss&explain=1&u=5214', badlocation = 1
WHERE sessionhash = '134a2328b51cb33f023ae60304ac6c97'
Time Before: 0.13070 seconds
Time After: 0.15459 seconds
Time Taken: 0.02389 seconds
Memory Before: 5,856.297 KB
Memory After: 5,856.500 KB
Memory Used: 0.203 KB
Page generated in 0.12966108322144 seconds with 9 queries, spending 0.035611391067505 doing MySQL queries and 0.094049692153931 doing PHP things.
