Time Before: 0.01021 seconds
Time After: 0.01334 seconds
Time Taken: 0.00313 seconds
Memory Before: 2,056.352 KB
Memory After: 2,081.469 KB
Time Before: 0.01344 seconds
Time After: 0.01391 seconds
Memory Before: 2,081.406 KB
Memory After: 2,082.414 KB
Time Before: 0.01415 seconds
Time After: 0.01427 seconds
Memory Before: 2,082.992 KB
Memory After: 2,083.516 KB
WHERE title IN ('smiliecache','bbcodecache','banemail','ranks','noavatarperms','navdata','options','bitfields','attachmentcache','forumcache','usergroupcache','stylecache','languagecache','products','pluginlist','cron','profilefield','loadcache','noticecache','activitystream','routes')
1SIMPLEdatastorerangePRIMARYPRIMARY52 21Using where
Time Before: 0.01521 seconds
Time After: 0.01810 seconds
Time Taken: 0.00289 seconds
Memory Before: 2,086.141 KB
Memory After: 2,087.078 KB
Memory Used: 0.938 KB
Time Before: 0.01432 seconds
Time After: 0.02225 seconds
Time Taken: 0.00792 seconds
Memory Before: 2,082.766 KB
Memory After: 3,171.813 KB
Memory Used: 1,089.047 KB
Time Before: 0.02679 seconds
Time After: 0.02703 seconds
Memory Before: 3,664.609 KB
Memory After: 3,665.227 KB
			phrasegroup_timezone AS phrasegroup_timezone,
			phrasegroup_cprofilefield AS phrasegroup_cprofilefield,
			phrasegroup_cppermission AS phrasegroup_cppermission,
Time Before: 0.03035 seconds
Time After: 0.03400 seconds
Time Taken: 0.00365 seconds
Memory Before: 3,676.570 KB
Memory After: 3,676.445 KB
Memory Used: -0.125 KB
Time Before: 0.02619 seconds
Time After: 0.03420 seconds
Time Taken: 0.00801 seconds
Memory Before: 3,656.789 KB
Memory After: 3,806.570 KB
Memory Used: 149.781 KB
Time Before: 0.05741 seconds
Time After: 0.05765 seconds
Memory Before: 4,411.047 KB
Memory After: 4,411.563 KB
Time Before: 0.06916 seconds
Time After: 0.07042 seconds
Memory Before: 4,498.742 KB
Memory After: 4,499.336 KB
End call of global.php: 0.072667121887207
Time Before: 0.07940 seconds
Time After: 0.07970 seconds
Memory Before: 5,135.852 KB
Memory After: 5,136.281 KB
WHERE templateid IN (62234,62232,55071,57273,57295,62316,0,0,6082,38961,42855,57213,38966,57292,5992,38968,38969,57230,62031,62305,45486,61981,53288,61979,61980,62335,0,0,62315,62276,62001,62002,62004,62005,62228,62347,62329,62279,62280,61828,61827,61831,61422,61391,61420,61659)
1SIMPLEtemplaterangePRIMARYPRIMARY4 43Using where
Time Before: 0.08259 seconds
Time After: 0.08548 seconds
Time Taken: 0.00288 seconds
Memory Before: 5,406.578 KB
Memory After: 5,407.844 KB
Memory Used: 1.266 KB
SET location = '/forums/profile.php?do=switchusercss&explain=1&u=58395'
Time Before: 0.10140 seconds
Time After: 0.10177 seconds
Memory Before: 5,844.836 KB
Memory After: 5,845.047 KB
Page generated in 0.10045719146729 seconds with 9 queries, spending 0.012420177459717 doing MySQL queries and 0.088037014007568 doing PHP things.
