Time Before: 0.02033 seconds
Time After: 0.02905 seconds
Time Taken: 0.00872 seconds
Memory Before: 2,056.352 KB
Memory After: 2,081.469 KB
Time Before: 0.02913 seconds
Time After: 0.02951 seconds
Memory Before: 2,081.406 KB
Memory After: 2,082.414 KB
Time Before: 0.02982 seconds
Time After: 0.02998 seconds
Memory Before: 2,082.992 KB
Memory After: 2,083.516 KB
Time Before: 0.03084 seconds
Time After: 0.03319 seconds
Time Taken: 0.00235 seconds
Memory Before: 2,086.141 KB
Memory After: 2,087.078 KB
Memory Used: 0.938 KB
Time Before: 0.03006 seconds
Time After: 0.03785 seconds
Time Taken: 0.00779 seconds
Memory Before: 2,082.766 KB
Memory After: 3,171.813 KB
Memory Used: 1,089.047 KB
Time Before: 0.04867 seconds
Time After: 0.04946 seconds
Time Taken: 0.00079 seconds
Memory Before: 3,664.609 KB
Memory After: 3,665.227 KB
Time Before: 0.05308 seconds
Time After: 0.05722 seconds
Time Taken: 0.00413 seconds
Memory Before: 3,676.570 KB
Memory After: 3,676.445 KB
Memory Used: -0.125 KB
Time Before: 0.04784 seconds
Time After: 0.05752 seconds
Time Taken: 0.00968 seconds
Memory Before: 3,656.789 KB
Memory After: 3,806.570 KB
Memory Used: 149.781 KB
Time Before: 0.08835 seconds
Time After: 0.08851 seconds
Memory Before: 4,411.047 KB
Memory After: 4,411.563 KB
Time Before: 0.10973 seconds
Time After: 0.11101 seconds
Memory Before: 4,498.742 KB
Memory After: 4,499.336 KB
Time Before: 0.12500 seconds
Time After: 0.12516 seconds
Memory Before: 5,135.852 KB
Memory After: 5,136.281 KB
Time Before: 0.12807 seconds
Time After: 0.13072 seconds
Time Taken: 0.00265 seconds
Memory Before: 5,406.578 KB
Memory After: 5,407.844 KB
Memory Used: 1.266 KB
UPDATE session SET location = '/forums/profile.php?do=switchusercss&explain=1&u=63144', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.15293 seconds
Time After: 0.15384 seconds
Time Taken: 0.00091 seconds
Memory Before: 5,845.094 KB
Memory After: 5,845.313 KB
