Time Before: 0.01638 seconds
Time After: 0.02196 seconds
Time Taken: 0.00558 seconds
Memory Before: 2,056.352 KB
Memory After: 2,081.469 KB
Time Before: 0.02209 seconds
Time After: 0.02256 seconds
Memory Before: 2,081.406 KB
Memory After: 2,082.414 KB
Time Before: 0.02281 seconds
Time After: 0.02294 seconds
Memory Before: 2,082.992 KB
Memory After: 2,083.516 KB
Time Before: 0.02377 seconds
Time After: 0.02643 seconds
Time Taken: 0.00265 seconds
Memory Before: 2,086.141 KB
Memory After: 2,087.078 KB
Memory Used: 0.938 KB
Time Before: 0.02303 seconds
Time After: 0.03021 seconds
Time Taken: 0.00718 seconds
Memory Before: 2,082.766 KB
Memory After: 3,171.813 KB
Memory Used: 1,089.047 KB
Time Before: 0.04066 seconds
Time After: 0.04105 seconds
Memory Before: 3,664.609 KB
Memory After: 3,665.227 KB
Time Before: 0.04358 seconds
Time After: 0.04696 seconds
Time Taken: 0.00338 seconds
Memory Before: 3,676.570 KB
Memory After: 3,676.445 KB
Memory Used: -0.125 KB
Time Before: 0.03989 seconds
Time After: 0.04720 seconds
Time Taken: 0.00731 seconds
Memory Before: 3,656.789 KB
Memory After: 3,806.570 KB
Memory Used: 149.781 KB
Time Before: 0.07307 seconds
Time After: 0.07322 seconds
Memory Before: 4,411.047 KB
Memory After: 4,411.563 KB
Time Before: 0.08823 seconds
Time After: 0.08954 seconds
Time Taken: 0.00131 seconds
Memory Before: 4,498.742 KB
Memory After: 4,499.336 KB
Time Before: 0.10322 seconds
Time After: 0.10339 seconds
Memory Before: 5,135.852 KB
Memory After: 5,136.281 KB
Time Before: 0.10565 seconds
Time After: 0.10730 seconds
Time Taken: 0.00164 seconds
Memory Before: 5,406.578 KB
Memory After: 5,407.844 KB
Memory Used: 1.266 KB
UPDATE session SET location = '/forums/profile.php?do=switchusercss&explain=1&u=64311', badlocation = 1 WHERE sessionhash = 'ba7fff4c8d66601b301d53cd735f0776'
Time Before: 0.12444 seconds
Time After: 0.12484 seconds
Memory Before: 5,845.094 KB
Memory After: 5,845.313 KB
