Time Before: 0.03440 seconds
Time After: 0.04230 seconds
Time Taken: 0.00791 seconds
Memory Before: 2,056.352 KB
Memory After: 2,081.469 KB
Time Before: 0.04240 seconds
Time After: 0.04285 seconds
Memory Before: 2,081.406 KB
Memory After: 2,082.414 KB
Time Before: 0.04312 seconds
Time After: 0.04330 seconds
Memory Before: 2,082.992 KB
Memory After: 2,083.516 KB
Time Before: 0.04425 seconds
Time After: 0.04659 seconds
Time Taken: 0.00234 seconds
Memory Before: 2,086.141 KB
Memory After: 2,087.078 KB
Memory Used: 0.938 KB
Time Before: 0.04337 seconds
Time After: 0.05035 seconds
Time Taken: 0.00699 seconds
Memory Before: 2,082.766 KB
Memory After: 3,171.813 KB
Memory Used: 1,089.047 KB
Time Before: 0.05789 seconds
Time After: 0.05824 seconds
Memory Before: 3,664.609 KB
Memory After: 3,665.227 KB
Time Before: 0.06113 seconds
Time After: 0.06454 seconds
Time Taken: 0.00341 seconds
Memory Before: 3,676.688 KB
Memory After: 3,676.563 KB
Memory Used: -0.125 KB
Time Before: 0.05722 seconds
Time After: 0.06479 seconds
Time Taken: 0.00757 seconds
Memory Before: 3,656.789 KB
Memory After: 3,806.688 KB
Memory Used: 149.898 KB
Time Before: 0.11392 seconds
Time After: 0.11410 seconds
Memory Before: 4,411.117 KB
Memory After: 4,411.633 KB
Time Before: 0.13362 seconds
Time After: 0.13493 seconds
Time Taken: 0.00131 seconds
Memory Before: 4,498.789 KB
Memory After: 4,499.383 KB
Time Before: 0.14799 seconds
Time After: 0.14816 seconds
Memory Before: 5,135.891 KB
Memory After: 5,136.320 KB
Time Before: 0.15025 seconds
Time After: 0.15205 seconds
Time Taken: 0.00179 seconds
Memory Before: 5,406.914 KB
Memory After: 5,408.180 KB
Memory Used: 1.266 KB
UPDATE session SET lastactivity = 1776738396, location = '/forums/profile.php?do=switchusercss&explain=1&u=69353' WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.16780 seconds
Time After: 0.16808 seconds
Memory Before: 5,845.109 KB
Memory After: 5,845.328 KB
