Time Before: 0.00144 seconds
Time After: 0.00194 seconds
Memory Before: 2,056.789 KB
Memory After: 2,081.906 KB
Time Before: 0.00202 seconds
Time After: 0.00258 seconds
Time Taken: 0.00056 seconds
Memory Before: 2,081.844 KB
Memory After: 2,082.852 KB
Time Before: 0.00287 seconds
Time After: 0.00301 seconds
Memory Before: 2,083.461 KB
Memory After: 2,083.984 KB
WHERE title IN ('smiliecache','bbcodecache','banemail','ranks','noavatarperms','navdata','options','bitfields','attachmentcache','forumcache','usergroupcache','stylecache','languagecache','products','pluginlist','cron','profilefield','loadcache','noticecache','activitystream','routes')
1SIMPLEdatastorerangePRIMARYPRIMARY52 21Using where
Time Before: 0.00370 seconds
Time After: 0.00641 seconds
Time Taken: 0.00272 seconds
Memory Before: 2,086.609 KB
Memory After: 2,087.547 KB
Memory Used: 0.938 KB
Time Before: 0.00306 seconds
Time After: 0.01019 seconds
Time Taken: 0.00713 seconds
Memory Before: 2,083.203 KB
Memory After: 3,172.195 KB
Memory Used: 1,088.992 KB
Time Before: 0.01190 seconds
Time After: 0.01231 seconds
Memory Before: 3,665.016 KB
Memory After: 3,665.633 KB
			phrasegroup_timezone AS phrasegroup_timezone,
			phrasegroup_cprofilefield AS phrasegroup_cprofilefield,
			phrasegroup_cppermission AS phrasegroup_cppermission,
Time Before: 0.01470 seconds
Time After: 0.01748 seconds
Time Taken: 0.00278 seconds
Memory Before: 3,676.992 KB
Memory After: 3,676.867 KB
Memory Used: -0.125 KB
Time Before: 0.01137 seconds
Time After: 0.01767 seconds
Time Taken: 0.00630 seconds
Memory Before: 3,657.164 KB
Memory After: 3,806.961 KB
Memory Used: 149.797 KB
Time Before: 0.02310 seconds
Time After: 0.02350 seconds
Memory Before: 4,411.461 KB
Memory After: 4,411.977 KB
Time Before: 0.02532 seconds
Time After: 0.02664 seconds
Time Taken: 0.00133 seconds
Memory Before: 4,499.133 KB
Memory After: 4,499.727 KB
End call of global.php: 0.028268098831177
Time Before: 0.02935 seconds
Time After: 0.02952 seconds
Memory Before: 5,137.289 KB
Memory After: 5,137.734 KB
Memory Used: 0.445 KB
WHERE templateid IN (62234,62232,55071,57273,57295,62316,0,0,6082,38961,42855,57213,38966,57292,5992,38968,38969,57230,62031,62305,45486,61981,53288,61979,61980,62335,0,0,62315,62276,62001,62002,62004,62005,62228,62347,62329,62279,62280,61828,61827,61831,61422,61391,61420,61659)
1SIMPLEtemplaterangePRIMARYPRIMARY4 43Using where
Time Before: 0.03135 seconds
Time After: 0.03278 seconds
Memory Before: 5,408.031 KB
Memory After: 5,409.297 KB
Memory Used: 1.266 KB
SET location = '/forums/profile.php?do=switchusercss&explain=1&u=69722', badlocation = 1
Time Before: 0.04483 seconds
Time After: 0.04508 seconds
Memory Before: 5,846.539 KB
Memory After: 5,846.758 KB
Page generated in 0.04394006729126 seconds with 9 queries, spending 0.010191917419434 doing MySQL queries and 0.033748149871826 doing PHP things.
