Time Before: 0.00156 seconds
Time After: 0.00202 seconds
Memory Before: 2,056.789 KB
Memory After: 2,081.906 KB
Time Before: 0.00210 seconds
Time After: 0.00267 seconds
Time Taken: 0.00058 seconds
Memory Before: 2,081.844 KB
Memory After: 2,082.852 KB
Time Before: 0.00297 seconds
Time After: 0.00310 seconds
Memory Before: 2,083.461 KB
Memory After: 2,083.984 KB
Time Before: 0.00390 seconds
Time After: 0.00686 seconds
Time Taken: 0.00296 seconds
Memory Before: 2,086.609 KB
Memory After: 2,087.547 KB
Memory Used: 0.938 KB
Time Before: 0.00316 seconds
Time After: 0.01143 seconds
Time Taken: 0.00828 seconds
Memory Before: 2,083.203 KB
Memory After: 3,172.195 KB
Memory Used: 1,088.992 KB
Time Before: 0.01336 seconds
Time After: 0.01377 seconds
Memory Before: 3,665.016 KB
Memory After: 3,665.633 KB
Time Before: 0.01616 seconds
Time After: 0.01951 seconds
Time Taken: 0.00334 seconds
Memory Before: 3,676.992 KB
Memory After: 3,676.867 KB
Memory Used: -0.125 KB
Time Before: 0.01273 seconds
Time After: 0.01969 seconds
Time Taken: 0.00696 seconds
Memory Before: 3,657.164 KB
Memory After: 3,806.961 KB
Memory Used: 149.797 KB
Time Before: 0.02527 seconds
Time After: 0.02538 seconds
Memory Before: 4,411.461 KB
Memory After: 4,411.977 KB
Time Before: 0.02718 seconds
Time After: 0.02842 seconds
Memory Before: 4,499.133 KB
Memory After: 4,499.727 KB
Time Before: 0.03120 seconds
Time After: 0.03134 seconds
Memory Before: 5,137.289 KB
Memory After: 5,137.734 KB
Memory Used: 0.445 KB
Time Before: 0.03330 seconds
Time After: 0.03515 seconds
Time Taken: 0.00184 seconds
Memory Before: 5,408.031 KB
Memory After: 5,409.297 KB
Memory Used: 1.266 KB
UPDATE session SET location = '/forums/profile.php?do=switchusercss&explain=1&u=71720' WHERE sessionhash = '295cc732df117534f65c11ae631a16f6'
Time Before: 0.04978 seconds
Time After: 0.05011 seconds
Memory Before: 5,846.258 KB
Memory After: 5,846.492 KB
Memory Used: 0.234 KB
