Time Before: 0.01955 seconds
Time After: 0.02494 seconds
Time Taken: 0.00539 seconds
Memory Before: 2,056.352 KB
Memory After: 2,081.469 KB
Time Before: 0.02504 seconds
Time After: 0.02548 seconds
Memory Before: 2,081.406 KB
Memory After: 2,082.414 KB
Time Before: 0.02575 seconds
Time After: 0.02594 seconds
Memory Before: 2,082.992 KB
Memory After: 2,083.516 KB
WHERE title IN ('smiliecache','bbcodecache','banemail','ranks','noavatarperms','navdata','options','bitfields','attachmentcache','forumcache','usergroupcache','stylecache','languagecache','products','pluginlist','cron','profilefield','loadcache','noticecache','activitystream','routes')
1SIMPLEdatastorerangePRIMARYPRIMARY52 21Using where
Time Before: 0.02678 seconds
Time After: 0.02913 seconds
Time Taken: 0.00235 seconds
Memory Before: 2,086.141 KB
Memory After: 2,087.078 KB
Memory Used: 0.938 KB
Time Before: 0.02601 seconds
Time After: 0.03331 seconds
Time Taken: 0.00730 seconds
Memory Before: 2,082.766 KB
Memory After: 3,171.813 KB
Memory Used: 1,089.047 KB
Time Before: 0.04136 seconds
Time After: 0.04178 seconds
Memory Before: 3,664.609 KB
Memory After: 3,665.227 KB
			phrasegroup_timezone AS phrasegroup_timezone,
			phrasegroup_cprofilefield AS phrasegroup_cprofilefield,
			phrasegroup_cppermission AS phrasegroup_cppermission,
Time Before: 0.04428 seconds
Time After: 0.04561 seconds
Time Taken: 0.00133 seconds
Memory Before: 3,676.570 KB
Memory After: 3,676.445 KB
Memory Used: -0.125 KB
Time Before: 0.04061 seconds
Time After: 0.04582 seconds
Time Taken: 0.00521 seconds
Memory Before: 3,656.789 KB
Memory After: 3,806.570 KB
Memory Used: 149.781 KB
Time Before: 0.07565 seconds
Time After: 0.07605 seconds
Memory Before: 4,411.047 KB
Memory After: 4,411.563 KB
Time Before: 0.09137 seconds
Time After: 0.09262 seconds
Memory Before: 4,498.742 KB
Memory After: 4,499.336 KB
End call of global.php: 0.094630002975464
Time Before: 0.10075 seconds
Time After: 0.10093 seconds
Memory Before: 5,135.852 KB
Memory After: 5,136.281 KB
WHERE templateid IN (62234,62232,55071,57273,57295,62316,0,0,6082,38961,42855,57213,38966,57292,5992,38968,38969,57230,62031,62305,45486,61981,53288,61979,61980,62335,0,0,62315,62276,62001,62002,62004,62005,62228,62347,62329,62279,62280,61828,61827,61831,61422,61391,61420,61659)
1SIMPLEtemplaterangePRIMARYPRIMARY4 43Using where
Time Before: 0.10335 seconds
Time After: 0.10449 seconds
Time Taken: 0.00114 seconds
Memory Before: 5,406.578 KB
Memory After: 5,407.844 KB
Memory Used: 1.266 KB
SET location = '/forums/profile.php?do=switchusercss&explain=1&u=73940'
Time Before: 0.12205 seconds
Time After: 0.12235 seconds
Memory Before: 5,844.836 KB
Memory After: 5,845.047 KB
Page generated in 0.12101411819458 seconds with 9 queries, spending 0.0079860687255859 doing MySQL queries and 0.11302804946899 doing PHP things.
