Time Before: 0.00228 seconds
Time After: 0.00336 seconds
Time Taken: 0.00108 seconds
Memory Before: 2,056.789 KB
Memory After: 2,081.906 KB
Time Before: 0.00347 seconds
Time After: 0.00394 seconds
Memory Before: 2,081.844 KB
Memory After: 2,082.852 KB
Time Before: 0.00420 seconds
Time After: 0.00441 seconds
Memory Before: 2,083.461 KB
Memory After: 2,083.984 KB
Time Before: 0.00530 seconds
Time After: 0.00766 seconds
Time Taken: 0.00235 seconds
Memory Before: 2,086.609 KB
Memory After: 2,087.547 KB
Memory Used: 0.938 KB
Time Before: 0.00449 seconds
Time After: 0.01253 seconds
Time Taken: 0.00804 seconds
Memory Before: 2,083.203 KB
Memory After: 3,172.195 KB
Memory Used: 1,088.992 KB
Time Before: 0.01453 seconds
Time After: 0.01501 seconds
Memory Before: 3,665.016 KB
Memory After: 3,665.633 KB
Time Before: 0.01734 seconds
Time After: 0.01869 seconds
Time Taken: 0.00136 seconds
Memory Before: 3,677.109 KB
Memory After: 3,676.984 KB
Memory Used: -0.125 KB
Time Before: 0.01388 seconds
Time After: 0.01895 seconds
Time Taken: 0.00507 seconds
Memory Before: 3,657.164 KB
Memory After: 3,807.078 KB
Memory Used: 149.914 KB
Time Before: 0.02649 seconds
Time After: 0.02667 seconds
Memory Before: 4,411.609 KB
Memory After: 4,412.125 KB
Time Before: 0.02888 seconds
Time After: 0.03012 seconds
Memory Before: 4,499.281 KB
Memory After: 4,499.875 KB
Time Before: 0.03302 seconds
Time After: 0.03319 seconds
Memory Before: 5,137.453 KB
Memory After: 5,137.898 KB
Memory Used: 0.445 KB
Time Before: 0.03518 seconds
Time After: 0.03628 seconds
Time Taken: 0.00110 seconds
Memory Before: 5,408.203 KB
Memory After: 5,409.469 KB
Memory Used: 1.266 KB
UPDATE session SET lastactivity = 1787594954, location = '/forums/profile.php?do=switchusercss&explain=1&u=80342' WHERE sessionhash = 'ba7fff4c8d66601b301d53cd735f0776'
Time Before: 0.04851 seconds
Time After: 0.04880 seconds
Memory Before: 5,846.609 KB
Memory After: 5,846.828 KB
