Time Before: 0.01538 seconds
Time After: 0.02074 seconds
Time Taken: 0.00536 seconds
Memory Before: 2,056.352 KB
Memory After: 2,081.469 KB
Time Before: 0.02084 seconds
Time After: 0.02142 seconds
Time Taken: 0.00057 seconds
Memory Before: 2,081.406 KB
Memory After: 2,082.414 KB
Time Before: 0.02172 seconds
Time After: 0.02198 seconds
Memory Before: 2,082.992 KB
Memory After: 2,083.516 KB
Time Before: 0.02289 seconds
Time After: 0.02544 seconds
Time Taken: 0.00255 seconds
Memory Before: 2,086.141 KB
Memory After: 2,087.078 KB
Memory Used: 0.938 KB
Time Before: 0.02206 seconds
Time After: 0.02948 seconds
Time Taken: 0.00743 seconds
Memory Before: 2,082.766 KB
Memory After: 3,171.813 KB
Memory Used: 1,089.047 KB
Time Before: 0.03486 seconds
Time After: 0.03524 seconds
Memory Before: 3,664.609 KB
Memory After: 3,665.227 KB
Time Before: 0.03758 seconds
Time After: 0.03894 seconds
Time Taken: 0.00136 seconds
Memory Before: 3,676.703 KB
Memory After: 3,676.578 KB
Memory Used: -0.125 KB
Time Before: 0.03421 seconds
Time After: 0.03916 seconds
Time Taken: 0.00495 seconds
Memory Before: 3,656.789 KB
Memory After: 3,806.703 KB
Memory Used: 149.914 KB
Time Before: 0.06452 seconds
Time After: 0.06469 seconds
Memory Before: 4,411.188 KB
Memory After: 4,411.703 KB
Time Before: 0.08002 seconds
Time After: 0.08129 seconds
Memory Before: 4,498.883 KB
Memory After: 4,499.477 KB
Time Before: 0.08954 seconds
Time After: 0.08979 seconds
Memory Before: 5,135.992 KB
Memory After: 5,136.422 KB
Time Before: 0.09235 seconds
Time After: 0.09349 seconds
Time Taken: 0.00114 seconds
Memory Before: 5,407.008 KB
Memory After: 5,408.273 KB
Memory Used: 1.266 KB
UPDATE session SET lastactivity = 1787594940, location = '/forums/profile.php?do=switchusercss&explain=1&u=82448' WHERE sessionhash = 'ba7fff4c8d66601b301d53cd735f0776'
Time Before: 0.11043 seconds
Time After: 0.11073 seconds
Memory Before: 5,845.336 KB
Memory After: 5,845.555 KB
