Time Before: 0.00541 seconds
Time After: 0.00717 seconds
Time Taken: 0.00177 seconds
Memory Before: 2,143.133 KB
Memory After: 2,169.914 KB
Memory Used: 26.781 KB
Time Before: 0.00728 seconds
Time After: 0.00773 seconds
Memory Before: 2,169.875 KB
Memory After: 2,170.852 KB
Time Before: 0.00796 seconds
Time After: 0.00809 seconds
Memory Before: 2,171.492 KB
Memory After: 2,172.016 KB
WHERE title IN ('smiliecache','bbcodecache','banemail','ranks','noavatarperms','navdata','options','bitfields','attachmentcache','forumcache','usergroupcache','stylecache','languagecache','products','pluginlist','cron','profilefield','loadcache','noticecache','activitystream','routes')
1SIMPLEdatastorerangePRIMARYPRIMARY52 21Using where
Time Before: 0.00907 seconds
Time After: 0.01181 seconds
Time Taken: 0.00274 seconds
Memory Before: 2,174.906 KB
Memory After: 2,175.844 KB
Memory Used: 0.938 KB
Time Before: 0.00816 seconds
Time After: 0.01526 seconds
Time Taken: 0.00710 seconds
Memory Before: 2,171.297 KB
Memory After: 3,260.547 KB
Memory Used: 1,089.250 KB
Time Before: 0.01754 seconds
Time After: 0.01794 seconds
Memory Before: 3,800.836 KB
Memory After: 3,801.453 KB
			phrasegroup_timezone AS phrasegroup_timezone,
			phrasegroup_cprofilefield AS phrasegroup_cprofilefield,
			phrasegroup_cppermission AS phrasegroup_cppermission,
Time Before: 0.02108 seconds
Time After: 0.02436 seconds
Time Taken: 0.00328 seconds
Memory Before: 3,813.195 KB
Memory After: 3,813.070 KB
Memory Used: -0.125 KB
Time Before: 0.01692 seconds
Time After: 0.02461 seconds
Time Taken: 0.00769 seconds
Memory Before: 3,793.547 KB
Memory After: 3,943.227 KB
Memory Used: 149.680 KB
Time Before: 0.03876 seconds
Time After: 0.03891 seconds
Memory Before: 4,628.977 KB
Memory After: 4,629.492 KB
Time Before: 0.05597 seconds
Time After: 0.05725 seconds
Memory Before: 5,106.625 KB
Memory After: 5,107.219 KB
End call of global.php: 0.059083938598633
Time Before: 0.06639 seconds
Time After: 0.06720 seconds
Time Taken: 0.00081 seconds
Memory Before: 6,171.297 KB
Memory After: 6,171.727 KB
WHERE templateid IN (62234,62232,55071,57273,57295,62316,0,0,6082,38961,42855,57213,38966,57292,5992,38968,38969,57230,62031,62305,45486,61981,53288,61979,61980,62335,0,0,62315,62276,62001,62002,62004,62005,62228,62347,62329,62279,62280,61828,61827,61831,61422,61391,61420,61659)
1SIMPLEtemplaterangePRIMARYPRIMARY4 43Using where
Time Before: 0.07013 seconds
Time After: 0.07159 seconds
Memory Before: 6,444.523 KB
Memory After: 6,445.789 KB
Memory Used: 1.266 KB
SET lastactivity = 1769077506, location = '/forums/profile.php?do=switchusercss&explain=1&u=95008', badlocation = 1
WHERE sessionhash = 'cb23636bbd36247f3b1133fdf383bca3'
Time Before: 0.08843 seconds
Time After: 0.08870 seconds
Memory Before: 6,933.711 KB
Memory After: 6,933.914 KB
Memory Used: 0.203 KB
Page generated in 0.087464094161987 seconds with 9 queries, spending 0.01095986366272 doing MySQL queries and 0.076504230499268 doing PHP things.
