Time Before: 0.01699 seconds
Time After: 0.02178 seconds
Time Taken: 0.00480 seconds
Memory Before: 2,056.352 KB
Memory After: 2,081.469 KB
Time Before: 0.02188 seconds
Time After: 0.02229 seconds
Memory Before: 2,081.406 KB
Memory After: 2,082.414 KB
Time Before: 0.02257 seconds
Time After: 0.02296 seconds
Memory Before: 2,082.992 KB
Memory After: 2,083.516 KB
Time Before: 0.02392 seconds
Time After: 0.02642 seconds
Time Taken: 0.00250 seconds
Memory Before: 2,086.141 KB
Memory After: 2,087.078 KB
Memory Used: 0.938 KB
Time Before: 0.02304 seconds
Time After: 0.03078 seconds
Time Taken: 0.00774 seconds
Memory Before: 2,082.766 KB
Memory After: 3,171.813 KB
Memory Used: 1,089.047 KB
Time Before: 0.03662 seconds
Time After: 0.03707 seconds
Memory Before: 3,664.609 KB
Memory After: 3,665.227 KB
Time Before: 0.04016 seconds
Time After: 0.04378 seconds
Time Taken: 0.00362 seconds
Memory Before: 3,676.688 KB
Memory After: 3,676.563 KB
Memory Used: -0.125 KB
Time Before: 0.03592 seconds
Time After: 0.04405 seconds
Time Taken: 0.00813 seconds
Memory Before: 3,656.789 KB
Memory After: 3,806.688 KB
Memory Used: 149.898 KB
Time Before: 0.07641 seconds
Time After: 0.07654 seconds
Memory Before: 4,411.117 KB
Memory After: 4,411.633 KB
Time Before: 0.08811 seconds
Time After: 0.08943 seconds
Time Taken: 0.00133 seconds
Memory Before: 4,498.789 KB
Memory After: 4,499.383 KB
Time Before: 0.09763 seconds
Time After: 0.09788 seconds
Memory Before: 5,135.891 KB
Memory After: 5,136.320 KB
Time Before: 0.10019 seconds
Time After: 0.10212 seconds
Time Taken: 0.00192 seconds
Memory Before: 5,406.914 KB
Memory After: 5,408.180 KB
Memory Used: 1.266 KB
UPDATE session SET lastactivity = 1789079989, location = '/forums/profile.php?do=switchusercss&explain=1&u=98938', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.12213 seconds
Time After: 0.12245 seconds
Memory Before: 5,845.391 KB
Memory After: 5,845.594 KB
Memory Used: 0.203 KB
